The topic you requested could not be found.
Optitrack Volume Add Camera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Volume Add Camera
There are 2 ways that Optitrack Camera can be added as part of the Optitrack Volume. Adding a Camera Manually From the Object tree, you can add an Optitrack Camera object manually and entering the serial number of the device manually. For details, please refer to…
Add/Setup Tracking Light Fixtures
Stage Precision » Stage Precision » Workflows » Light Tracking » Add/Setup Tracking Light Fixtures
Add Tracking Light Fixtures First we need to add some Tracking Light Fixtures within the object tree. Add Fixture Profile to the Fixtures Now we need to assign a Fixture Profile to the Tracking Light Fixtures. *If you don´t have a Fixture Profile yet please…
Snap to Point
Stage Precision » Stage Precision » Views / Elements » Inspector » Snap to Point
Snap to Point is a function to move objects or other position parameter to a specific location within the viewport. It’s possible to snap to subpoints from: Primitive Objects Imported Polygon Objects Splines Volume Points Rigid…
Float to Timecode
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Text Nodes » Float to Timecode
This node converts incoming float values into a timecode output. Setup Name Description Time This is the float input for the time value. Timecode This is the generated timecode output. Hours This is the…
Timecode to Float
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Text Nodes » Timecode to Float
This node converts timecode into float output values. Setup Name Description Timecode This is the timecode input. Time This is the output float value. Layout Name Description Position…
Euler to Quaternion
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Convert Nodes » Euler to Quaternion
This converts Euler values into Quaternion. Euler to Quaternion
Scripts to control Shield
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Scripts to control Shield
Within Stage Precision, function for Shield can be used within scripts node = specify a Shield node with the index. 0 send it to all nodes. "level" = level name as string. "path" = path as string. Level Change Shield1.changeLevel("level",…
Unix Timestamp to Date
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Convert Nodes » Unix Timestamp to Date
Unix Timestamp is a date and time representation that measures time by the number of seconds that have elapsed since 00:00:00 UTC on 1 January 1970. This node converts the Unix timestamp format to a Date format. Name Description Unix This…
Licenses
Stage Precision » Licenses
There are several different types of SP licenses. Core Director Engineer Full Bundle Kinetic Tracking & Interactive Trial Virtual Production Each license may have different limitations on functionalities. For more details, please visit our website All…
LOLED Virtual / LONET
Antilatency
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Antilatency
This is a native input for Antilatency tracking data. Antilatency is an inside-out tracking system provider for VR/AR, Virtual Production, MoCap, Drones and Robotics. !AntilatencyService v4.0.0 needs to run and connected on the same computere where SP is…
Adding License
Stage Precision » Licenses » Adding License
How to Obtain the License Key Once a license has been purchased successfully from our webstore an email should be sent to the registered email of the account with the license key attached in the email. Alternatively from the webstore, you are able to look at the…
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Remote control Blueprint Functions
Stage Precision can remote control functions from Blueprints Add a function !The BluePrint needs to be within the level to trigger the functions. Fetch for functions within the Shield IO, a click on the (I) *Check also the Board Interface Trigger the…
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Remote control Blueprint Events
Stage Precision can remote control custom events from Blueprints Add a custom event !The BluePrint needs to be within the level to trigger the events. Fetch for custom events within the Shield IO, a click on the (I) *Check also the Board…
Telegram Bot
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Telegram Bot
With the Telegram Bot IO it´s possible to send notifications from SP directly into your Telegram messenger. Use this to monitoring your systems and send notifications in case of failures or status updates. It´s also possible to send from Telegram a specific messages…
Visca Server
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » Visca Server
The Visca Server IO creates an Visca over IP endpoint, so that SP can be controlled from a Visca based PTZ controller. *This is only available for Virtual Production, Light Tracking, Engineer, and Full license. Setup the Visca Server Connection Add the Visca Server…
Optitrack Volume
Optitrack Volume is the representation of the tracking area from a group of optitrack cameras that have been calibrated. *This is only available for Tracking, Light Tracking, Full, and Engineer license. In order to have a working optitrack volume, the following steps…
PTZ Camera Control
Optitrack Camera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Camera
Optitrack provides a wide range of camera sensors for tracking purposes. SP supports the Optitrack Prime and Slim cameras. *This is only available for Tracking, Light Tracking, Full, and Engineer license. Adding the Sensor To add a connection to an Optitrack camera,…
PTZ
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ
All of the manufacturer specific PTZ camera objects would be organized under this category. Currently, we have the following manufacturer specific PTZ cameras: Panasonic UE 100 Panasonic UE 150 Panasonic UE 160 Sony BRC-X1000 Sony FR7 !The Sony camera…
Point Cloud Blob Tracking
Stage Precision » Stage Precision » Workflows » Blob Tracking Workflows » Point Cloud Blob Tracking
There are different ways to get tracking information within SP. One of them is to extract infromation from a set of point cloud data and do blob tracking from that. There are in general 2 main groups of point cloud that SP can process to do blob tracking on. They are…
The Static Calibration tool is to provide a quick and easy way to quickly align a static camera that does not move or do any pan/tilt/roll. At the end of this calibration, the camera would be placed relative to the calibration screen. *There will be NO lens profile…
Blickfeld Cube 1
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Blickfeld Cube 1
The Cube 1 from Blickfeld is a 3D-Lidar. SP can use the 3D-Pointcloud for Blobtracking. For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking, Full, and Engineer license. Add and Configurate Cube 1…
Reposition from Marker
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Reposition from Marker
The Reposition from Marker Tool is used to reposition a camera based on a predefined markers in 3D space instead of patterns on a screen. This tool can be used on a camera with a tracking system as well as static camera with no tracking system. Prerequisites A…
Late Tick calculations / Low Latency
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Late Tick calculations / Low Latency
With the Late Tick Calculation it´s possible to optimize the latency between input data, SP calculation and output data to a minimum. To open the Time Inspector follow this steps. Enable/Disable the Late Tick calculation. Shift the SP calculation within a…
DMX Merge
Stage Precision » Stage Precision » Workflows » Light Tracking » DMX Merge
Different signal flows can be supported. Merge within Stage Precision seperated networks By using multiple networks, it´s still possible to have the same patch for fixtures. SP is receiving the DMX network stream on one deticated network interface and send out on…
DMX Merge
Input Synchronization
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Synchronisation of IO Connection » Input Synchronization
Delay Input frames Whenever it´s necessary to add full frame delays to the incoming data packages, just increase this value. Interpolation Whenever the incoming data packages needs an interpolation. Might be necessary when the protocol fps is not equal with…
Interactive Trigger Area
Stage Precision » Stage Precision » Workflows » Interactive Trigger Area
Within SP, it is possible to define an area in 3D space for interactive purposes. Some of the things that SP can do once there is this defined area include: if an object has entered the area if an object has left the area when the defined area is empty if objects…
IO functions
Stage Precision » Stage Precision » Scripting » General use of Scripting » IO functions
For some IO-Connections are special functions avaiable. OSC: OSC.send("address", variable); To send a OSC value from a script you need to define the address/path and a value what you whant to send. The type of the value is depending of the type of your variable.…
Tracking Alignment
StreamDeck
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » StreamDeck
StreamDeck is a controller accessory for a PC. There are 2 different ways that a StreamDeck can be connected to SP. Direct Connection If the StreamDeck is directly connected to the SP machine via local USB, there is a StreamDeck object under the object tree inside…
Slack Bot
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Slack Bot
With the Slack Bot IO it´s possible to send notifications from SP directly into your Slack messenger. Use this to monitoring your systems and send notifications in case of failures or status updates. Prepare Slack It´s necessary to prepare Slack before using this…
Section Text
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Text Nodes » Section Text
This takes in the source text and trim the source text about the defined substring. Section Text Setup Name Description Source This is the input text. Substring This is the substring input. Include Substring…
Output Synchronization
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Synchronisation of IO Connection » Output Synchronization
Delay Output Frames Whenever it´s necessary to add full frame delays to the outgoing data packages, just increase this value. Time Inspector The Time Inspector shows the outgoing data packages. To open the Time Inspector click within the IO on the…
Alignment with Marker
Panasonic UE 100 / UE 150 / UE 160
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Panasonic UE 100 / UE 150 / UE 160
For the general configuration on how to work with a PTZ camera, please refer to here. In this page, we will be mainly focusing on how to setup a Panasonic PTZ camera, specifically the UE 100, UE 150, and the UE160. Configure PTZ camera to send out FreeD Data In…
On top of doing a Lens Calibration and Tracking Alignment, the camera object has some extra tools to help reposition multiple screens based on the captured images. Prerequisites: Tracking system data into SP Media input into SP A camera object within…
New Window
Stage Precision » Stage Precision » Views / Elements » New Window
This is a separate SP window that allows the docking of any of the views to this window. The way to dock and move views into this window is the same way as with the main SP window.
Shield Live Link
Shield for Unreal » Setting & Functions (v0.8) » Shield Live Link
A Live Link connection will be automatically added when the project opens. Add SPNet Live Link connection If the connection is deleted manually it´s possible to add the connection again. !Check if the interface IP is the correct local network interface. If not,…
Reposition from Screens
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Reposition from Screens
The Reposition from Screen Tool is used to reposition a camera based on a known / pre-defined location of a screen. This tool can be used on a camera with a tracking system as well as static camera with no tracking system. Prerequisites At least one calibration…
Screens Alignment
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Screens Alignment
The Screen Alignment Reposition Tool is used to reposition multiple screens based on a known calibrated tracked camera. *For this tool to work, the tracked camera needs at least Pan/Tilt encoders, but ideally a full 6DoF tracking system will generate better…
Distortion Viewer
Stage Precision » Stage Precision » Views / Elements » Objects » Tracked Objects » Camera » Distortion Viewer
The Distortion Viewer is a simple preview to visualize the distortion Values of the Camera object. There is one layer where a source can be distorted and another layer with an not distorted source. These layers can be combined to see if the distortion values matched…
Stage Precision » Stage Precision » Workflows » Light Tracking » Calibration with self-generated values
Instead of using the lighting desk to focus on the measurement point during the calibration process, it´s also possible to position the fixture directly from SP. Make sure that SP has the full control Bring all Mix parameter to the minimum. Start Batch…
Preferences
Stage Precision » Stage Precision » General settings » Preferences
Global OSC Remote Startup and Update Name Description Launch on system startup When on Stage Precision will startup when the computer starts up. Launch Minimised When on Stage Precision will load minimized. …
Define Measurement Points
Stage Precision » Stage Precision » Workflows » Light Tracking » Define Measurement Points
To calibrate the Tracking Light Fixtures we need some reference points within the tracking area. This points should be “reachable/lightable” from all light fixtures and should be easy to measure. *We should have at least 5 measurement points for a good…
Lens & Tracking Calibration
0.8.117
Stage Precision » Changelog » 0.8.117
Features: - #275 General – Artist/Studio license check now active - #271 General – new target selector to select tragets with mouse - #264 General – floating windows by default “always on top” - #272 IOConnections – Gateway can now…
Focusing on Points
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Focusing on Points
The Focusing on Points Reposition Tool is used to update an existing Alignment Profile of a tracked camera. Typically this is used when the already aligned tracking system has been nudged / shifted slightly and only want to do a quick re-alignment. Prerequisites A…
Genlock / Reference
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Genlock / Reference
Genlock Name Description Genlock Provider The specific genlock IO connection can be selected, using the target button. Interpolation Type Full interpolation None interpolation *The fps has four different color…
Shield actor
Shield for Unreal » Setting & Functions (v0.8) » Shield actor
The Shield actor is a CineCamera based actor. This actor takes care about the different render passes, includes lens distortion, processed shadow / reflection catcher and can be driven over Live Link. !Supported is one single Shield actor per level. !All…
Pixotope Gateway
Stage Precision » Stage Precision » Views / Elements » IO Connections » Realtime Engine » Pixotope Gateway
Pixotope is a real-time rendering engine based on Unreal Engine for virtual studios, augmented reality, extended reality, mixed reality, and virtual production applications. This IO connection act as a wrapper to the Pixotope Gateway API. Pixotope Gateway …
Sony FR7
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Sony FR7
Prepare the camera First the freeD feedback output needs to be activated Make sure, that this values are matching with the SP settings: - Camera ID - Destination IP - Destination Port Enable Visca for the FR7 Enable Tally over Visca Range the Zoom and…
Kinetics and Physics Simulation
Stage Precision » Stage Precision » Workflows » Kinetics and Physics Simulation
SP has a built in Physics engine and can be used to simulate an object with mass being hung/driven from motorized winches. Prerequisite 1 x Kinetic Construction 1+ x Kinetic Driver IO connection to receive the kinetic driver information from Setup Make sure…
Calibration Screens
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens
Multiscreen Single Screen Infinity Screen !It is extremely important that the settings in SP for the calibration screen for the size of the marker, starting marker ID, resolution of the screen, size of the screen are all configured to match what the real world…
Releasing License
Stage Precision » Licenses » Releasing License
Releasing a license from a machine frees the license so that it could be added to another machine. How to Release a License from an Online Machine Open the License Manager of SP via the Help menu. From the License Manager window, you would be able to see all of…
Ultraleap / Leapmotion
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Ultraleap / Leapmotion
Ultraleap are sensors to detect hand movements. Install Driver To use the Ultraleap devices within SP you need first install their driver: Download Driver Add Sensor Within the object tree navigate to sensors and choose “Ultraleap”. Choose…
Stage Precision » Stage Precision » Workflows » Blob Tracking Workflows » Blob Tracking Management with Volume
Using the Volume object to manage the Point Data From the previous step either from the “Image Based Blob Tracking “:http://manual.stageprecision.com/stage.precision.beta/en/topic/image-based-blob-trackingor” Point…
Mif 4 (Rosendahl)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Peripheral » Mif 4 (Rosendahl)
The mif4 Rosendahl is an interface to professional timecode. This IO connection allows SP to communicate with the Mif4 device and go into the different state. Once a Mif4 IO connection has been created, new SP actions can be created for this device. Trigger…
License
Shield for Unreal » Settings & Functions (UE5) » License
*Unreal 5 From the Shield Setting tab, the first option is to manage your Shield License. A pop up window open for the License settings. When there is no license activated on a machine, there will be watermark on the outputs and a pop up similar to this would…
Changelog
Shield for Unreal » Changelog
1.7.1 Features: Support for UE 5.4.1 Invert option for Matte Passes All render passes are now available as Render Target new Actor (PointDataActor) – can automatically spawn Classes from the SP volume Shadow-Catcher supports now BP Actor New render pass…
Kinesys
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Kinesys
Kinesys is an automation control system. Kinesys system can provide winch position data and also rigid body data. *For now, SP has only implemented the connection to receive winch position information from Kinesys system. Kinesys Setup Kinesys Name…
Modbus
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » Modbus
Modbus is a communication protocol on the transport layer allowing multiple devices to connect and communicate with each other on the same cable or Ethernet network. There are several versions of Modbus protocol and the one that is supported by SP is Modbus…
Shield
Stage Precision » Stage Precision » Views / Elements » IO Connections » Realtime Engine » Shield
Shield is an Unreal plugin provided by Stage Precision. for more details about how to connect Shield with SP please refer to here.
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Remote control Material Parameter
Stage Precision can remote control parameter from Material Parameter Collections. They can be used within Unreal materials. Create a Material Parameter Collections Link the Material Parameter Collection within the Shield Settings Create parameter which…
Alignment Profile
Stage Precision » Stage Precision » Views / Elements » Pool » Alignment Profile
This is a profile for aligning the tracking system’s incoming data to the SP world coordinate. This is generated from tools under the Camera Calibration workflow. For more information, please click here.
DMX Patch
Stage Precision » Stage Precision » Workflows » Light Tracking » DMX Patch
Add DMX IO Add a sACN and/or ArtNet IO connection. Add DMX maps to the fixtures !If the DMX merging should happen on the same “universe”, make sure that you add seperated IO´s for In- and Output on seperated network interfaces. *See here the…
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Tracking Light Fixture » DMX Channels Tracking Light Fixture (Controller Map In)
Channel bit Parameter Defaults 1 16bit Target Id* 0 3 8bit Target Fade in 1/10s 0 4 8bit Mixed Pos** 255 5 8bit Mixed Brightness** 255…
Shield Settings
Shield for Unreal » Setting & Functions (v0.8) » Shield Plugin Settings » Shield Settings
!Shield Settings are only relevant when using a Shield actor. !All settings are also available as Blueprint within Unreal. To access the Shield Settings, simply click within unreal on the general “Settings” icon and click on “Shield…
Objects
The objects section is where all fixtures, objects and structures are stored and arranged. When SP initially starts up the objects view will be in the top left-hand corner. The objects section includes all of the scene building models, fixtures and shapes. To add…
1.1
Gateway » Changelog » 1.1
Improvements: Key Press with Modifiers now supports multiple modifiers Gateway board interface CPU and RAM usage reporting Overlay Fixes: disable wallpaper info now works issues with “ctrl” and “shift” modifiers. !SP Version 1.1.90 is…
Hyperdeck
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Hyperdeck
Hyperdeck Studio are professional broadcast decks that record and playback media. A Hyperdeck can be remotely controlled from SP. Setup the Hyperdeck IO-Connection define the Hyperdeck IP address (Remote Host) and select the local interface Trigger…
StreamDeck
Stage Precision » Stage Precision » Views / Elements » Objects » Controller » StreamDeck
The StreamDeck is a customizable OLED button control interface. By creating a StreamDeck object under the object tree allows you to directly connect to a StreamDeck device and configure the buttons’ design and functions within SP. !Early versions of the…
RoboSense Lidar
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » RoboSense Lidar
Robosense is a manufacturer of 3D LIDAR sensors. These lidars can be used within SP to generate tracking information out of the 3D point cloud. For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking,…
Log
Stage Precision » Stage Precision » Views / Elements » Log
The log displays all activity within SP, including incoming and outgoing data. *Below is an example of how information is stored.
Optitrack Alignment
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Alignment
Once all the cameras has been calibrated and their relative position between each other has been reconstructed, the next step is to offset / translate the entire group of cameras so the tracking volume is aligned with the 3D space within SP. There are several options…
Virtual Camera Fly
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Virtual Camera Fly
Virtual Camera Fly is a function within Stage Precision to use full virtual camera animations or extend the actual tracked camera. The Live Input within Shield stays at the defined location and will manipulate the scale and perspective of the camera feed, as if it…
Optitrack Camera Setup
The controller section contains controller devices, these devices can be added in and programmed to control different parameters within SP. The IO connections within this section are: GamePad Joystick StreamDeck 3D Connexion
d&b Soundscape
Stage Precision » Stage Precision » Views / Elements » IO Connections » Audio » d&b Soundscape
d&b Soundscape is an audio system processor to realize object-based mixing. www.dbsoundscape.com Stage Precision can drive the “audio-objects” among other things with realtime tracking data, controller inputs, timeline based programming and…
Event
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Event Nodes » Event
Events are things that happen within SP and can trigger internal and external messages to be output. This is an event node, any object can be added to cause an event. Event Setup Name Description Event This displays the event…
Stage Precision specialises in being a digital intermediary between different devices in 3D space. We connect tracking and positioning systems with media servers and lighting desks, we drive complex kinetic installations and we deliver flawless tracking solutions as a…
Keyboard Shortcuts
Stage Precision » Stage Precision » Keyboard Shortcuts
*Keyboard shortcuts are completely interchangeable and can be customised. A step by step guide on how to change the maps can be found in the ‘Preferences’. The shortcuts can be located under ‘Help > Shortcuts’ or by pressing ‘Shift +…
Single Screen
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens » Single Screen
Setting Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the Object check the settings under “Display”…
FactoryOptic – Syncro-Link
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » FactoryOptic – Syncro-Link
Syncro-Link from FactoryOptic is a lens readout system. This device sends Zoom, Focus and Iris as ranged values from 0-100% into a Camera object. *This is only available for Virtual Production, and Full license. Add the FactoryOptic connection The FactoryOptic IO…
Multiscreen
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens » Multiscreen
A calibration multiscreen can be used to calibrate curved or other shaped LED-Walls. Basic configuration of defining the screen size, resolution and marker IDs are the same as a Single Screen. For details please refer to here. *You can export a Multiscreen as FBX …
Web Camera
Stage Precision » Stage Precision » Views / Elements » IO Connections » Image Provider » Web Camera
This is a native connection where any available camera connections can be added from the SP machine, these include USB web cameras and virtual cameras such as OBS or NDI. Web Camera Setup Name Description Camera The camera can be selected…
VLC
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » VLC
To control VLC from Stage Precision it´s necessary to define some settings first. Prepare VLC for remote control 1. Open the preferences 2. Change the “show settings” in the lower right corner select “All” 3. Activate Web …
Mo-Sys Axis Example
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » F4 (Mo-Sys) » Mo-Sys Axis Example
This is an example using the F4 (Mo-Sys) axis map inputs for a jib/crane that where there is a rotational pivot at the base a rotation encoder on the arm a remote pivot head mounted at the end of the arm. A camera is then mounted at the remote pivot head with a…
Gateway
Gateway
Gateway is a small application which can be run on multiple machines in your network. It possible to send trigger commands with SP to one or several remote Gateway instances. Gateway Preferences Gateway IO in Stage Precision Commands from Stage Precision Gateway…
Import
Stage Precision » Stage Precision » General settings » Import
With the importer it’s possible to import FBX files and SP Lens Profiles. FBX import This mesh objects from a 3D software should be imported. Go to the “File” menu and click on “Import” and select the FBX file. *You also can…
Process Rate
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Process Rate
Prossesses can be found on the title bar, this contains the Main Process Rate of Stage Precision. Name Description Main Process Rate All calculations and all synced Outputs will be locked to this timing. Gui Refresh Rate…
All time critical IO Connections have advanced synchronization options. This options can be found in the tab “sync” within the added IO. In- and Outputs can be delayed per frame as well as within subframes. Inputs can be have different additional…
Views / Elements
The layout of the user interface can be altered. The layout sections can be found under the View tab. Inspector Objects IO Connections Input Interpolation Viewport Timeline Timeline Recording Board & Nodes Monitor Mapping2D Pool Log Viewer Layer…
AJA Kumo
Stage Precision » Stage Precision » Views / Elements » IO Connections » Switcher » AJA Kumo
AJA Kumo is a professional video router. A AJA Kumo can be remotely controlled from SP. Setup the AJA Kumo IO-Connection define the AJA Kumo IP address (Kumo IP). Trigger Maps Trigger Maps can be “called” among other things within interface objects…
Text
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Text
Text Object is a two dimensional text label that exists in the 3D space of SP and is viewable from the viewport. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. …
