BlackMagic Design HyperDeck is a professional broadcast deck that records and playback media.
HyperDeck Setup
Remote Host | This is where the IP address of the host can be input. |
Remote Port | This is the port that the data package will be sent to. |
Interface | This is the IP address of the local network interface which should be used for this connection. |
Is Connected | When on, the device is connected. |
Status
Last Transport | Reports the last Transport Status |
is Recording | Shows the status if the unit is in recording mode |
Timecode | Shows the timecode that the unit is receiving |
Clip ID | Shows the current clip ID |
Trigger Maps
Trigger Maps can be called among other things within interface objects like Buttons, Dropdowns, Timeline Trigger Layer, Areas, Nodes, and many more. There is several types of trigger map available for the HyperDeck.
Record | Trigger to record current input |
Play | Trigger to play from current timecode |
Stop | Trigger to stop playback or recording |
Goto Timecode | jump to specified timecode |
Jog Timecode | Jog to specified timecode |
Set Playback Range | Set play range to play between “Start Timecode” and “End Timecode” |
Clear Playback Range | Clear / reset play range setting |
Set Loop True | Enable play in Loop |
Set Loop False | Disable play in Loop |
Goto Clip | Go to clip with the specified Clip ID |
Next Clip | Trigger to skip to the next clip |
Previous Clip | Trigger to go to the start of the current clip |
