This is a virtual representation of the human body, with 24 joints that correspond to points on the body. Each of the joints have 11 different properties; colour, depth, camera and orientation in the X, Y and Z axis.
Scale |
Rotation |
Velocity |
This is the speed of the object in the direction it is traveling along the X, Y and Z axis. |
Acceleration |
This is the rate of change of the velocity of the object. |
Tracked State |
Type |
Kinect Skeleton – This skeleton corresponds to the human body when being tracked by a Kinect. With 24 joints that match up to points on the body, such as head, neck, right and left hand. |
Display Object |
Display Label |
Locked |
Object Colour |
Double click the colour block and this will open a colour picker. This can be used to change the object display colour. |
Viewport Scale |
Dimensions of the object in the viewport in meters. |
Display SubPoints |
By turning this on the subpoints of the object will be displayed. When turned off only the main point of the object will be visible. |
Points
Points |
Points or joints long the skeleton which corresponds to areas on the body. |
Point Position |
Positional data of each point along X, Y and Z axis. |
Input Mapping
Output Mapping
Type |
- Input – The nodes input values are determined by incoming values from an external source.
- Output – The node is outputting data to another source.
Target Object |
This is the object that will either be affected by the incoming values or output information. |
The directional XYZ values will be displayed here. |
Rotation |
The rotational XYZ values will be displayed here. |
Enabled |
When on, the parameter is active and enabled. |
Display Colour |
This colour block can be changed by changing the parameter. |
Editable |
When on, the node is editable. |
Locked |
