The Yocto-Color-V2 is a RGB LED driver.
The Yocto-Color-V2 IO can be added with a click on the (+) within the IO Connections.
Within the Inspector the Yocto-Color-V2 needs to know the connection mode (USB or Network) and add the device Serial.
The Yocto-Color-V2 Node has two color input pins.
This example shows how to link two color field values into the Yocto-Color-V2 Node
