This is a native input for Blacktrax tracking data.
Blacktrax (RTTrPM) Setup
Input
Multicast Connection |
When on, data can be sent to multiple recipients. |
Multicast Target IP |
Interface |
Integer – These are whole numbers. |
Local Port |
Is Bound |
Server |
Server name will be displayed here when connected. |
*Check the Calibration/Allignment Tool here.
Input Mapping
Type |
- Centroid – The position of the object will be affected by the center of the blacktrax data.
- LED – This will handle the individual LED tracking data separately.
ID |
The ID of the point can be added and the positional data from that point will be used. |
Led |
This is the number of the LED point. |
When on, the position of the object will be affected. |
Rotation |
When on, the rotation of the object will be affected. |
Velocity |
When on, the velocity of the object will be affected. |
Acceleration |
When on, the acceleration of the object will be affected. |
Transform
- Global Position – The object will be affected by the global position of the data.
- Relative Position – The position of the object will be relative to the tracking data.
- Global Effected Position – The position of the object will be dependent on the global effected position.
Rotation |
- Global Rotation – The object will be affected by the global rotational data.
- Relative Rotation – The rotation of the object will be relative to the tracking data.
- Global Effected Rotation – The rotation of the object will be dependent on the global effected rotation.
Status
Tracked State |
Enable Recording |
When on, the tracking data can be recorded. |
Compatible input objects
