The tracker can take the form of rigid bodies or points. These objects can be controlled by or output positional data as well as acting as measuring points or triggers.
| Velocity | This is the speed of the object in the direction it is traveling along the X, Y and Z axis. |
| Acceleration | This is the rate of change of the velocity of the object. |
Tracker
| Tracked State |
Userdata
| Display Trace | The trace is a trail that follows the tracker and shows the direction of movement. When un-ticked there will be no trace. |
| Trace Time | This determines how long the trace is displayed before it disappears. |
| Trace Colour | Clicking the colour box opens a colour picker with RGB (red, green, blue) and alpha control. |
| Display | This allows you to change the shape of the tracker – choosing between a cube, sphere or crosshair. |
| Radius | Distance from the center of the object to the edge of the circle in meters. |
| Display SubPoints | By turning this on the subpoints of the object will be displayed. When turned off only the main point of the object will be visible. |
Specific Tracker Filters
Prediction Filter
| Weight | This is the amount this filter effects the object. |
| Prediction Time | This is the amount the data will be predicted to help smooth the movement of the object. |
| Cyclic | The filter will use reoccurring movements to help predict the movement of the object. |
| Use Position | When ticked the filter will affect the position of the object. |
| Use Rotation | When ticked the filter will affect the rotation of the object. |
| Target Object | This is the object that will either be affected by the incoming values or output information. |
| Position | The directional XYZ values will be displayed here. |
| Rotation | The rotational XYZ values will be displayed here. |
| Enabled | When on, the parameter is active and enabled. |
| Display Colour | This colour block can be changed by changing the parameter. |
| Tracked Status | This indicates whether the status is Active, Undefined or Inactive, with the values -1, 0 and 1. 1 indicating that the tracking status is active. |
| Tracked Age |
