Add a IO Connection “Gateway” in Stage Precision.
You need to define the Gateway IP. This is the IP address of a computer in your network where Gateway is running.
The Gateway Port needs to stay on 37777.
If you want to use the WakeOnLan function you also needs to fill in the Mac address of the network interface from the same computer like above.
Multicast IP needs to stay at 237.37.37.37
Local Port needs to stay on 47777.
Interface is your local network adapter wich is connected to the computer network where the computer with the Gateway instance is connected.
You can drag and drop the Gateway IO on a Board to get a interface of this remoted Gateway instance.
By a secondary click on the interface you get quick access to some commands.
