The Shield actor is a CineCamera based actor.
This actor takes care about the different render passes, includes lens distortion, processed shadow / reflection catcher and can be driven over Live Link.
Add a Shield actor
Within the “Place Actor” windows, select the category Shield and drag the Shield Actor in the level.
Shield actor properties
Transform
| Parameter | Description | Change in play | SP control |
| Location | X positive = forwards / X negative = backwards Y positive = right / Y negative = left Z positive = up / Z negative = down values in cm |
| Rotation | X positive = anti clockwise roll / X negative = clockwise roll Y positive = up tilt (pitch) / Y negative = down tilt (pitch) Z positive = right pan (yaw) / Z negative = left pan (yaw) values in degrees |
| Jump Into View on Begin Play | If checked, the viewport is automatically locked to this camera view, if editor is on play. | |
| Current Focal Length | the camera focal length in mm | |
| Current Aperture | the camera aperture as “f-number” | |
| Focus distance | the focus distance in cm | |
| Current Horizontal FOV | the curent FoV on degrees read only |
Camera – Lens Distortion
| K1-K3 | radial distortion values | |
| Center Shift | lens shift value | |
| Overscan | overscan factor to avoid missed rendered gaps caused by the distortion | |
Camera – Camera Settings
| Sensor Width | the width of the camera sensor in mm | |
| Sensor Height | the height of the camera sensor in mm | |
| Smooth Focus Change | enable this to use interpolation to smooth out changes in focus distance. When disabled, the focus changes will be instantaneous. |
| Draw Focus Plane | enable to draw a translucent plane at the current focus depth. This enables a visual way to track where the focus is for the shot. |
| Diaphragm Blade Count | the number of blades that make up the diaphragm mechanism. | |
Reflection & Shadow Catcher
ShadowCatcherSettings
| Enable | enable/disable the Shadow Catcher | |
| Alpha multiplier | the intensity of the catcher within the render passes | |
ReflectionCatcherSettings
Split Scene Options
| Clip method |
Post Process Volume
| Post Process Volume | All post process settings known from a normal Cine Camera Actor. | |
Objects Lists
These lists define the objects for the different tasks/passes.
Live Link Controller
Live Link Subject
| Subject Representation | This is the Live Link driver for the Shield actor | |
