This converts combined colour data into separate CMYK (Cyan, Magenta, Yellow, Black) float values.
Colur2CMYK Setup
Colour |
This displays the input colour. |
C |
This is the output value of the cyan parameter. |
M |
This is the output value of the magenta parameter. |
Y |
This is the output value of the yellow parameter. |
K |
This is the output value of the black parameter. |
Size |
