Shotover G1 is a lightweight, weather resistant, gyro-stabilized gimbal platform.
Shotover
Local Port |
is Bound |
Type |
Choose between Unicast, Multicast, and Broadcast mode |
Multicast Target IP |
Interface |
This is the IP address of the local network interface which should be used for this connection. |
Calibration
Offset Pos |
The amount of translational offset |
Offset Scale |
The scale factor for translational data |
Offset Rot |
The amount of Rotational offset |
Align Tool |
Opens the Alignment window to calculate the offset |
Clear Offset |
Trigger to clear the calibrated offset |
