This is a linear effector, where the changed parameters only work within or around the effector itself.
Scale |
Rotation |
Weight |
This is the amount that the objects are affected, the higher the number the more the objects are affected. |
Position along the X, Y and Z axis, that the objects will move when interacting with the effector. |
Rotation |
Rotation along the X, Y and Z axis, that the objects will do when interacting with the effector. |
Colour |
Clicking the colour box opens a colour picker with RGB (red, green, blue) and alpha control. |
Falloff
Type |
- Infinite – This will affect everything within the visualizer.
- Sphere – The area that is affected will be defined by the radius of the sphere.
- Cube – The area that is affected will be defined by the size of the cube.
- Linear – The area that is affected will be defined by the side or direction of the linear plane.
Position Type |
- Original Object Position – This will affect the objects from their original positions.
- Effected Position – The objects will be affected by the position of the effector.
Falloff |
When increased this will create a feathered effect to the affected area, if at 0 the falloff point will be a line. |
Radius |
Distance from the center of the object to the edge of the circle in meters. |
Cube Size |
Dimensions of the cubes width, height and length. |
Invert |
When ticked, the effector will only affect objects within its shape. When un-ticked, it will invert the effect and only affect those outside the shape. |
Effected Objects
Parameter
Target |
A target object can be selected by using the trigger button. The target object/s will be affected by the effector. |
Filter |
- Tracker
- Pixel
- Spotlight
- Light Fixture
- Winch
- Winch2
- Winch3
Display Object |
Display Label |
Locked |
Object Colour |
Double click the colour block and this will open a colour picker. This can be used to change the object display colour. |
Viewport Scale |
Dimensions of the object in the viewport in meters. |
Video Tutorial
Plain Effector setup begins at 00:45.
The plain effector can be manipulated in the board by adding the effector as a node, this can be done by clicking and dragging the specific effector on the board.
Type |
- Input – The nodes input values are determined by incoming values from an external source.
- Output – The node is outputting data to another source.
Target Object |
This is the object that will either be affected by the incoming values or output information. |
The directional XYZ values will be displayed here. |
Rotation |
The rotational XYZ values will be displayed here. |
Enabled |
When on, the parameter is active and enabled. |
Displayed Colour |
This colour block can be changed by changing the parameter display colour. |
Editable |
When on, the node is editable. |
Locked |
