The Shield actor is a CineCamera based actor.
This actor takes care about the different render passes, includes lens distortion, processed shadow / reflection catcher and can be driven over Live Link.
Add a Shield actor
Within the “Place Actor” windows, select the category Shield and drag the Shield Actor in the level.
Shield actor properties
Transform
Parameter Description Change in play SP control
Location X positive = forwards / X negative = backwards
Y positive = right / Y negative = left
Z positive = up / Z negative = down
values in cm
Rotation X positive = anti clockwise roll / X negative = clockwise roll
Y positive = up tilt (pitch) / Y negative = down tilt (pitch)
Z positive = right pan (yaw) / Z negative = left pan (yaw)
values in degrees
Jump Into View on Begin Play If checked, the viewport is automatically locked to this camera view, if editor is on play.
Current Focal Length the camera focal length in mm
Current Aperture the camera aperture as “f-number”
Focus distance the focus distance in cm
Current Horizontal FOV the curent FoV on degrees
read only
Camera – Lens Distortion
K1-K3 radial distortion values
Center Shift lens shift value
Overscan overscan factor to avoid missed rendered gaps caused by the distortion
Camera – Camera Settings
Sensor Width the width of the camera sensor in mm
Sensor Height the height of the camera sensor in mm
Smooth Focus Change enable this to use interpolation to smooth out changes in focus distance.
When disabled, the focus changes will be instantaneous.
Draw Focus Plane enable to draw a translucent plane at the current focus depth.
This enables a visual way to track where the focus is for the shot.
Diaphragm Blade Count the number of blades that make up the diaphragm mechanism.
Reflection & Shadow Catcher
ShadowCatcherSettings
Enable enable/disable the Shadow Catcher
Alpha multiplier the intensity of the catcher within the render passes
ReflectionCatcherSettings
Split Scene Options
Clip method
  • Foreground List
  • Full Object Culling
  • Full Object Culling (Volume Based)
  • Clip Plane
Post Process Volume
Post Process Volume All post process settings known from a normal Cine Camera Actor.
Objects Lists
These lists define the objects for the different tasks/passes.
Live Link Controller
Live Link Subject
Subject Representation This is the Live Link driver for the Shield actor
Live Link World Transform
