| Name |
| Gateway IP |
The Ip address can be selected by using the grey button or entered manually. |
| Gateway Port |
This is the port number that data will be sent to. |
| Max Address |
| Multicast Ip |
| Local Port |
| Multicast Connection |
When on multicast will be used. |
| Interface |
| Use in Loopback |
When on the data will be used in loopback. |
| Is Bound |
