Pandoras Box is a high-quality media server.
Pandoras Box Setup
| Name |
| Server IP |
This is where the IP address of the server can be added. |
| Interface |
| Port |
This is the port that the data package will be sent to. |
| Domain |
The domain number can be added here. |
Pandoras Box Mapping
Maps Out
| Name |
| Site ID |
The site ID number can be added here. |
| Device ID |
The device ID number can be added here. |
| Use Position |
When on the position data will be output. |
| Use Rotation |
When on the rotation data will be output. |
| Use Scale |
When on the scale data will be output. |
| Direct Mode |
When on the data will be on direct mode. |
| Silent Mode |
When on the device will be on silent mode. |
Transform
| Name |
| Position |
- Global Position – The global position will be output.
- Relative Position – The relative position will be output.
- Global Effected Position – The global effected position will be output.
- Target Position – The target position will be output.
| Rotation |
- Global Rotation – The global rotation of the object will be output.
- Relative Rotation – The relative rotation will be output.
- Global Effected Rotation – The global effected rotation will be output.
Advanced Sharing Options
| Name |
| Trigger Send |
Pressing this button will send out a trigger value. |
| Use on Change |
When on, the trigger will be output in a time interval. |
| Use on Interval |
The time interval can be altered in milliseconds. |
| Timer Interval (ms) |
Compatible Output Objects
Node Mapping
| Name |
| Module Info |
The module information will be displayed here when connected. |
| Site Id |
The site Id can be manually added using the slider or manually inputting the number. |
| Device Id |
The device Id can be manually added using the slider or manually inputting the number. |
| Parameter Name |
The parameter name can be manually added by clicking in the box. |
- Float – Individual X, Y or Z data.
- Integer – These are whole numbers.
| Direct Mode |
When on, the node is set to direct mode. |
| Silent Mode |
When on, the node is set to silent mode. |
| Value |
The input value will be displayed here when connected. |
| Name |
| Editable |
When on, the node is editable. |
| Locked |
