Instead of using the lighting desk to focus on the measurement point during the calibration process, it´s also possible to position the fixture directly from SP.
Make sure that SP has the full control
Bring all Mix parameter to the minimum.
Start Batch Calibration
Select your fixtures and start the calibrator from the inspector.
Select a single fixture
Select a single row/fixture which should be positioned.
Set all Fixtures to Pan Tilt mode
Set the position to a calibration point
Repeat this with all fixtures
Position all fixtures to one calibration point before continue.
Add a calibration point
Choose from the dropdown the measurement point where the real light fixtures are “pointing/focusing” to and click on “Add or Update”
Continue calibration
Repeat this steps with all other calibration points.
Execute the calibration
before calibration
after calibration
