A Web Target (link) can be assigned to a Button to open a webpage if the board is used as webserver.
Open the container web.
External link
Define the link adress inkl. “http://” to open this if the button is pressed on a webserver.
Open now this Board in a Webbrowser to open this link.
Link to an other Board
This Web Target can also be used to jump from one Board to an other.
Click on an empty space within the board to get the board settings in the Inspector.
A secondary click on the parameter name (Url) to copy the adress (parameter value).
http://localhost:8088/angular/boards/board
This is the default address of a board called “board”.
If the name of the Board will change the link will change as well.
By renaming the board to “Test” the link will be:
http://localhost:8088/angular/boards/test
