This is a 3D body that moves under physics and collides with other objects.
| Velocity | This is the speed of the object in the direction it is traveling along the X, Y and Z axis. |
| Acceleration | This is the rate of change of the velocity of the object. |
Rigid Body Parameters
| Point Count | Number of points that make up the rigid body. |
| Construct Rigid | Button to create the rigid body once the points have been assigned. |
| Align in Center | Button to align the rigid body to the center of the points. |
| Rotate Rigid | Button to rotate the rigid body to the rotation of the points. |
Point Parameters
| Link | This is where the assigned points can be selected to build the rigid body. |
| Rel Position | This is the position of the selected point. |
| Tracked | This can be turned on and off. When on the points coordinates will be tracked. |
| Display Trace | The trace is a trail that follows the tracker and shows the direction of movement. When un-ticked there will be no trace. |
| Trace Time | This determines how long the trace is displayed before it disappears. |
| Trace Colour | Double-clicking the colour box opens a colour picker with RGB (red, green, blue) and alpha control. |
| Display | This allows you to change the shape of the tracker – choosing between a cube, sphere or crosshair. |
| Radius | Distance from the center of the object to the edge of the circle in meters. |
| Target Object | This is the object that will either be affected by the incoming values or output information. |
| Position | The directional XYZ values will be displayed here. |
| Rotation | The rotational XYZ values will be displayed here. |
| Enabled | When on, the parameter is active and enabled. |
| Display Colour | This colour block can be changed by changing the parameter. |
