The winch 3 object has three chain and hook points arranged in a triangle. These can be attached to one object and allow for rotation as well as linear movements.
Winch Control
| Target Height | Distance from the winch to the end of the chain or subobject. |
| Rotation X | Rotation of the subobject on the X axis from 0 to 100 degrees. |
| Rotation Y | Rotation of the subobject on the Y axis from 0 to 100 degrees. |
| 1 – Value in % | Equivalent percentage value to the target height and rotation Y value. |
| 2 – Value in % | Equivalent percentage value to the target height and rotation X and Y values. |
| 3 – Value in % | Equivalent percentage value to the target height and rotation X and Y values. |
Configuration
| Drive Range Min | The closest distance the chain or object can be to the winch. |
| Drive Range Max | The maximum distance that the chain can travel from the winch. |
| Limit Range | If ticked it enables the use of the range clipping min and range clipping max. |
| Range Clipping Min | Minimum distance the winch can travel with in the drive range min. |
| Range Clipping Max | Maximum distance the winch can travel with in the drive range max. |
| Min X Rotation | By setting a minimum rotation it prevents the subobject from rotating past this point on X axis. |
| Max X Rotation | By setting a maximum rotation it prevents the subobject from rotating past this point on X axis. |
| Min Y Rotation | By setting a minimum rotation it prevents the subobject from rotating past this point on Y axis. |
| Max Y Rotation | By setting a maximum rotation it prevents the subobject from rotating past this point on X axis. |
| Speed | Maximum speed which the winch subobject can travel. |
| Drive Subobjects | If ticked this will control any objects which have been made a child of the winch, as if they are attached to the winch chain. |
| Subobject Offset | Offset distance between the subobject and winch body. |
| Motor Group Width | This is the width in meters between the motors. |
| Motor Group Height | This is the height in meters between the motors. |
| Target Object | This is the object that will either be affected by the incoming values or output information. |
| Position | The directional XYZ values will be displayed here. |
| Rotation | The rotational XYZ values will be displayed here. |
| Enabled | When on, the parameter is active and enabled. |
| Display Colour | This colour block can be changed by changing the parameter. |
