3D Connexion Setup
Status The status of the device connection will be displayed here.
3D Connexion Mapping
Maps In
Use Position When on, the input position data will be used.
Position Factor This is the input position value.
Use Rotation When on, the input rotation data will be used.
Rotation Factor This is the input rotation value.
Status
Tracked State
  • Undefined – When tracker does not have a map input.
  • Inactive – When the tracker has a follow object input map.
  • Active – When the tracker has a target object map input.
Enable Recording When on, the tracking data can be recorded.
Compatible Input Objects
Node Mapping
Module Info The module information will be displayed here.
Position This is the incoming positional data.
Rotation This is the incoming rotational data.
Button Left When on, the left button is active.
Button Right When on, the right button is active.
Editable When on, the node is editable.
Locked When on, the node is locked into its position on the board.
