| Name |
| Client IP |
The Ip address can be added manually or pressing the grey button will open a drop-down list. |
| Client Port |
The client port can be added manually or by using the slider. |
| Display Points |
When on, the points will be displayed. |
| Show Image |
- Depth
- Blob
- Coloured Blob
- Mask
| Image Update Rate |
- Setup (10fps)
- Run (1fps)
- None
| Load Settings |
The settings will be loaded by pressing the button. |
| Write Settings |
| Camera |
The specific camera can be selected using the target button. |
Input
| Name |
| Multicast Target IP |
| Local Port |
| Interface |
| Is Bound |
| Name |
| Min Radius |
The minimum radius can be set here. |
| Near Threshold |
The near-threshold of the image can be set. |
| Far Threshold |
The far threshold of the image can be set. |
| Erode |
| Dilate |
| Blur |
The blur amount can be set here. |
Blob
| Name |
| Min Radius |
| Max Radius |
The maximum radius can be set here. |
| Persistence |
| Max Distance |
Exclude
| Name |
| Top |
This is the amount the image will be cropped from the top. |
| Bottom |
This is the amount the image will be cropped from the bottom. |
| Left |
This is the amount the image will be cropped from the left. |
| Right |
This is the amount the image will be cropped from the right. |
Rectangle and Polygon
Rectangles and Polygons can be added by pressing the + button.
Rectangle
| Name |
| Position |
The XY position can be set here. |
| Size |
The size of the rectangle XY can be set here. |
Polygon
| Name |
| Point 1 |
The XY position of the point can be set here. |
| Point 2 |
| Point 3 |
| Point 4 |
