The OSC IO connection can be used within the node system.
Simply drag and drop the IO-Connection onto the Board and choose the needed node.
The OSC nodes supports the following connection types which can be defined within the Inspector:
- Float
- Integer
- String
- Color
- Vector
- Point
- Bool
Whether it is a sender or receiver the Node needs to know which “Path” should be use to receive or send the data.
This can be happen within the Inspector or also with a connection of the type “String”.
