Gateway IP |
The Ip address can be selected by using the grey button or entered manually. |
Gateway Port |
This is the port number that data will be sent to. |
Max Address |
Multicast Ip |
Local Port |
Multicast Connection |
When on multicast will be used. |
Interface |
This is the IP address of the local network interface which should be used for this connection. |
Use in Loopback |
When on the data will be used in loopback. |
Is Bound |
