The monitor can be used to display changes in individual parameters over a period of time.
Monitor Setup
Parameter The parameter can be selected using the target button.
Type
  • Continious
  • Time frame
Show Value Graph When on the value graph of parameter changes will be displayed in the monitor window.
Show Time Delta Graph When on a graph showing the fluctuation of movement over time.
Show X value When on the values from the X axis will be displayed.
Show Y value When on the values from the Y axis will be displayed.
Show Z value When on the values from the Z axis will be displayed.
Time frame duration The duration of the monitor view can be altered here.
Clear Pressing this button will clear the monitor window.
Save on Timeline Pressing this button will save the movement data onto the timeline.
Limit data count The maximum amount of data that can be processed by the monitor can be set.
Graphs
When the value graph is on the XYZ parameters will be displayed in the corresponding colour to the axis (X – red, Y – green and Z – blue).
When the time delta graph is on the frequency and fluctuation and movement of the parameter.
