Input Filters
Tracking
Window Size |
This is the size of the tracking area. |
Reset Position threshold |
The position threshold can be altered here. |
Reset Interpolation Time |
The interpolation time can be reset here. |
Move Interpolation Time |
The interpolation time can be adjusted here. |
Interpolate Mode |
When on the position will be affected by the interpolation tracking filter. |
Manipulation
Offset
Offset Position |
The position of the object can be offset from the data by meters along the X, Y and Z axis. |
Offset Rotation |
The rotation of the object can be offset from the data by degrees, on the X, Y and Z axis. |
Process Priorities
Input Filter |
If ticked the filter will be applied to the input data. |
Pre Calculation Filter |
If ticked this filter will be applied pre-calculation of the data. |
Post Calculation Filter |
If ticked this filter will be applied post calculation of the data. |
Velocity Influence
Max Velocity |
The maximum velocity can be set manually or by using the slider. |
Influence |
The velocity curve can be edited by manipulating this filter curve. |
Limit
Limit Position |
When turned on the movement of the object will be limited by the maximum and minimum values. |
Minimum |
This is the min amount of movement along the X, Y and Z axis. |
Maximum |
This is the max amount of movement along the X, Y and Z axis. |
Limit Rotation |
When ticked the rotation of the object will be limited. |
Range Position
Input minimum |
Any positional data lower than this min will not affect the object. |
Input Maximum |
Any positional data higher than this max will not affect the object. |
Output Minimum |
The object will not output positional data below this min position. |
Output Maximum |
The object will not output positional data above this max position. |
Clamp Values |
When this is turned on it will stop the object from moving past the minimum and maximum coordinates. |
Reduction
Merge Average |
This will find an average of all the data received and affect the object based on the average. |
Merge |
This will merge all data. |
Interpolated Center |
- Dampening – The reduction in the amount of fluctuation in the data. If the data is lost the object will move smoothly to the center until the data is back.
- Time Linear – If the data is lost the object will move to the center over a time fade.
- Time Cubic – If the data is lost the object will snap back to the center.
Manipulation
Limit
Limit Position |
Minimum |
Maximum |
Limit Rotation |
Offset
Offset Position |
Offset Rotation |
Process Priorities
Input Filter |
Velocity Influence
Max Velocity |
Influence |
Range Position
Input minimum |
Input Maximum |
Output Minimum |
Output Maximum |
Clamp Values |
Speed Limit
Input Filter |
Process Priorities
Smoothing
*Check out this nice webpage to compare different types of smoothing filter: InteractiveDemo
Biquad
Type |
Fc |
Q |
PeakGainDB |
When on the position will be affected. |
Rotation |
When on the rotation will be affected. |
Inertia
Damping |
Inertia |
Process Priorities
Velocity Influence
Max Velocity |
Influence |
OneEuro
Min Cutoff |
This is the minimum frequency cutoff. |
Beta |
This is the cut off of the smoothing slope. |
D Cutoff |
This is the frequency cutoff for the derivative. |
Rotation |
Smoothing
Mode |
- Median – This is the middle value of the window of data.
- Moving average – This takes an average of the window of data.
- Weighted moving average – This is a smoothing filter of pan and tilt fixtures.
Damping |
This is the amount of dampening done to the incoming data, the smaller the number the more the effect. |
Window Size |
This indicated the size of the selection window of the data, the larger the number the larger amount of data will be used by the median, moving average and weighted moving average mode types. |
When turned on the smoothing filter will be applied. |
Rotation |
Target
Align on Spline
Spline Target |
A spline object can be assigned by clicking on the target button. |
On Spline Position |
Toggling from 0.00 to 100, moves the object around the assigned spline. |
Target Coordinates |
Target destination these coordinates are where the object should finish moving. |
Follow Object
Target Object |
An object can be assigned as a target by clicking on the target button. |
Use Position |
When on, the tracker will be attached to the center of its assigned object. |
Use Rotation |
When on, the tracker will follow the rotation of its assigned object. |
Use Points |
When turned on, individual points can be selected to follow. |
Point |
The points number can be selected here. |
*This Filter has predefined Templates to link all Camera paramters.
Target On
Target Object |
*Use the “relative object” target to drive parent object from the view of the child (relative) object.
In this case the parent object has the filter but the target on filter will be calculatet by the “view” from the attached and offseted camera object.
