This switch node is able to take in multiple values, as well as a switch value which controls which of the input values are outputted.
Type |
- Float – Individual X, Y or Z data.
- Integer – These are whole numbers.
- Point – This sends out XY data.
- Vector – Combined XYZ data.
Switch |
This value determines which ‘In’ input value is output. |
In 1 |
This is the first float input value. |
In 2 |
This is the second float input value. |
In 3 |
This is the third float input value. |
In 4 |
This is the fourth float input value. |
In 5 |
This is the fifth float input value. |
In 6 |
This is the sixth float input value. |
In 7 |
This is the seventh float input value. |
In 8 |
This is the eighth float input value. |
In 9 |
This is the ninth float input value. |
In 10 |
This is the tenth float input value. |
Out |
This is the selected output value. |
Size |
