This places a standard camera in the 3D space. This camera can be set to a perspective or orthogonal view.
Scale |
Rotation |
Camera Setup
Tracked State |
Active In Editor |
Pressing this switches the viewport camera to this camera. |
Camera Parameter
Projection |
- Perspective – This camera view allows for a three-dimensional view, representing depth, width and height.
- Orthogonal – This camera view gives a two-dimensional view of the three-dimensional space.
Field of View |
The field of view is part of the area of the world that is visible through the camera. |
Aperture |
The aperture of the camera can be set here. |
Focus Distance |
This is the minimum distance where the camera is still able to focus. |
Focus Length |
This is the maximum distance where the camera is still able to focus. |
Focus |
The focus in percentage can be set here. |
Zoom |
The zoom in percentage can be set here. |
Iris |
The amount of light able to enter through the iris can be set here. |
Lens Parameter (mm)
K1 |
This is a lens distortion parameter. |
K2 |
K3 |
P1 |
P2 |
Center X |
Movement of the center point along the X axis. |
Center Y |
Movement of the center point along the Y axis. |
Lens Parameter (px)
K1 |
K2 |
This is a radial distortion of the lens. |
K3 |
This is a radial distortion of the lens |
P1 |
P2 |
Center X |
Center Y |
Resolution |
The resolution of the camera can be set here. |
Panel Size |
The panel size can be adjusted by width and height. |
Aspect Ratio |
The aspect ratio of the output can be set here. |
Near Clipping |
This is a set distance from the camera where any objects closer to the camera than this won’t be rendered. |
Far Clipping |
This is a set distance from the camera where any objects past this distance won’t be rendered by the camera. |
Iris Blades |
The amount the iris blades open can be set here. |
Display Object |
Display Label |
Locked |
Object Colour |
Double click the colour block and this will open a colour picker. This can be used to change the object display colour. |
Viewport Scale |
Dimensions of the object in the viewport in meters. |
Frustum Length |
The frustum refers to the region that can be seen and rendered by a perspective camera. This parameter alters the length of the region in meters. |
Filter
Camera specific filters
Input Mapping
Output Mapping
Type |
- Input – The nodes input values are determined by incoming values from an external source.
- Output – The node is outputting data to another source.
Target Object |
This is the object that will either be affected by the incoming values or output information. |
The directional XYZ values will be displayed here. |
Rotation |
The rotational XYZ values will be displayed here. |
Enabled |
When on, the parameter is active and enabled. |
Display Colour |
This colour block can be changed by changing the parameter. |
Editable |
When on, the node is editable. |
Locked |
