Stage Precision can remote control custom events from Blueprints
Add a custom event
Fetch for custom events
within the Shield IO, a click on the (I)
Trigger the custom event with a trigger map
create a run function map
with a click on the magnifyer all possible events will be shown
Add parameter to a custom event
Control these parameters also from Stage Precision
add parameters within the “run function” map
make sure that the type is equal to the parameter within Unreal
make sure that the name is equal to the parameter name within Unreal
with a secondary click on a parameter, it`s possible to change the name
