ADM OSC is an industry initiative for standardization of Object-Based Audio (OBA) positioning data in live production ecosystems by implementing the Audio Definition Model (ADM) over Open Sound Control (OSC).
| Send Mode |
| Cube Target | Target cube object used to define the range of the normalized values for the coordinate system |
Output Connection
| Remote Host | This is where the target IP address of the host can be input. |
| Remote Port | This is the port that the data package will be sent to. |
Map Output
This IO connection can be connected with some objects like a Tracker or Camera .
| Object Index | Define the index of the tracked object |
| Width | This is an optional parameter. Can be enabled and define the width of the ADM object |
