This node compares two input values and outputs the result if the value is true, this output lasts for a period of time which can be set.
Compare Period Setup
Type |
- Float – Individual X, Y or Z data.
- Integer – These are whole numbers.
Period |
This is the amount of time of the result. |
Function |
- == Equal (A=B).
- != Not Equal (A is not equal to B).
- < Smaller (A is smaller than B).
- <= Smaller Equal (A is smaller than or equal to B).
- > Bigger (A is larger than B).
- >= Bigger Equal (A is bigger than or equal to B).
Result |
When the equation is true the result will be on and output. |
A |
This is the first input value. |
B |
This is the second input value. |
Size |
