The Shield Widget is a user interface to monitor the different render passes and shows additional information.
Overview
The Shield Widget includes three different areas:
- Header and footer area
- Actor details
- Render passes
1. header and footer area
Within the header the following information is present:
Header
Connection |
Tracking Source |
Resolution | Project resolution |
FPS | actual frames per second |
Footer
Shows the following parameter from the Shield Actor:
Focal Length | the focal length in mm |
Horizontal FoV | the horizonal field of view in degrees |
Aperture | the aperture in f. |
Focus Distance | the focus distance in m |
Sensor Size | the sensor size in mm |
Timecode | the actual timecode |
Actor Details
Within this area a detailed view of the actual actor properties is shown.
Render Passes
Previews of the different render passes.
RGB only
The different “channels” can be chosen within the dropdown in the upper left corner.
