This is an integration with the TiMax Tracker which is a positional tracking system based on UWB technology.
TiMax Setup
Input
Port | This is the port that will receive data from other devices. |
Is Bound | This will be on when the IO connection is bound to a network. |
Type |
Multicast Target IP | If type is set to multicast, define the multicast target IP |
Interface | This is the IP address of the local network interface (NIC) which should be used for this connection. |
Input
ID | This is the ID number of the tracking point. |
