Q-sys ECP or Q-Sys External Control Protocol is used to communicate with the Q-Sys Designer Software and firmware.
Q-sys ECP
Remote Host | This is where the target IP address of the host can be input. |
Remote Port | This is the port that the data package will be sent to. |
Interface | This is the IP address of the local network interface (NIC) which should be used for this connection. |
Is Connected | When on, the Q-Sys Designer is connected. |
Login | If login credentials are needed |
Username | Username to login with |
Pin | Pin to login with |
Trigger Maps
Trigger Maps can be called among other things within interface objects like Buttons, Dropdowns, Timeline Trigger Layer, Areas, Nodes, and many more. There are 3 types of trigger maps available for Q-Sys ECP
Control Set String
Control ID | ID for the control |
String Value | String value to be passed over to Q-Sys Designer |
Control Set Value
Float Value | Floast value to be passed over to the Q-Sys Designer |
Ramp Time | Time in seconds to rmap up to the defined float value |
Custom Command
Custom Message |
