The Kinetic driver is a virtual “Rope/Hoist-System”.
*This is only available for Kinetic Control, Full, and Engineer license.
| Name |
| Position |
| Scale |
| Rotation |
Kinetic Driver
| Name |
| Length |
Length of the Kinetic Driver (rope/chain lenght) |
Physics
| Name |
| Method |
- Softbody Rope
- Constrain Rope
| Mass |
The mass of the Kinetic Driver |
| Segments |
The segment amount of the Kinetic Driver |
Configuration
| Name |
| Drive Range min |
define the minimum “drive” value (effects Length) |
| Drive Range max |
define the maximum “drive” value (effects Length) |
*Add a Map Input like PSN or Movecat to drive this Kinetic Driver with external data!
*You need to place these objects in your 3D space.
!You need a Kinetic Construction object to calculate with this Kinetic Driver.
