This is a trigger node with a delay value. The node takes in values from other nodes and outputs triggers whether the event is true or false.
Trigger Delayed Setup
Trigger |
When on, there is an input trigger value. |
Trigger Delay |
A time delay can be set. |
Switch to True |
This is the trigger value when the event is true. |
Switch to False |
This is the trigger value when the event is false. |
Size |
