Start Videohub Setup
Remote Host | This is where the IP address of the host can be input. |
Remote Port | This is the port that the data package will be sent to. |
Interface | This is the IP address of the local network interface which should be used for this connection. |
Is Connected | When on, the device is connected. |
Reconnect | This button can be pressed to reconnect the device. |
Get Status | The button can be pressed to get the status of the device. |
Test
Send Trigger | The trigger message can be manually added. |
Send | Pressing this button will output the trigger. |
Answer | The answer from the device will be displayed here. |
Configuration
Inputs | This is the number of the input. |
Outputs | This is the number of the output. |
Build Interface | Pressing the button will build an interface. |
Get Labels | Pressing the button will display labels. |
