This node converts incoming float values into a timecode output.
Time This is the float input for the time value.
Timecode This is the generated timecode output.
Hours This is the integer output of the hour value generated by the timecode.
Minutes This is the integer output for the minute value generated by the timecode.
Seconds This is the integer output for the second’s value generated by the timecode.
