*Keyboard shortcuts are completely interchangeable and can be customised. A step by step guide on how to change the maps can be found in the ‘Preferences’.
The shortcuts can be located under ‘Help > Shortcuts’ or by pressing ‘Shift + F1’.
General
| Name |
| New |
ctrl + N |
| Open |
ctrl + O |
| Open Last Document |
ctrl + shift + O |
| Save |
ctrl + s |
| Save As |
ctrl + shift + S |
| Select all |
ctrl + A |
| Copy |
ctrl + C |
| Cut |
ctrl + X |
| Paste |
ctrl + V |
| Duplicate |
ctrl + d |
| Delete |
‘delete’ ‘backspace’ |
| Preferences |
ctrl + |
| Project Settings |
‘ctrl ‘ ‘ctrl+shift’ |
| Select Previous Item |
‘cursur up’ ‘shift+cursor up’ |
| Select Next Item |
‘cursor down’ ‘shift+cursor down’ |
| Undo |
ctrl + Z |
| Redo |
‘ctrl + shift + Z’ ‘ ctrl + Y’ |
| About |
not mapped by default |
| Manual |
F1 |
| Tutorials |
| Shortcuts |
shift + F1 |
Application
| Name |
| Quit |
ctrl + Q |
SP
| Name |
| Lock Screen |
shift + F12 |
| Import SpE |
ctrl + I |
| Import FBX |
ctrl + alt + F |
| Export FBX |
ctrl + shift + E |
Viewport
| Name |
| Camera |
W |
| Move |
E |
| Rotate |
R |
Global
| Name |
| Selection Focus |
F |
| Home |
H |
Global
| Name |
| Delete Board |
Timeline
| Name |
| Play/Pause Sequence |
Spacebar |
| Previous Cue |
shift + page up |
| Next Cue |
shift + page down |
| edit Time |
T |
| Previous timestep |
Page up |
| Next timestep |
Page down |
| Go to start |
Home |
| Go to end |
End |
| Go to Preview start |
shift + Home |
| Go to Preview end |
shift + end |
| add Cue |
F9 |
| Add Info Cue |
| Add Play Cue |
| Add Pause Cue |
| Add Jump to Cue Cue |
| Add Jump to Time Cue |
| Set Preview Start |
B |
| Set Preview End |
N |
| Move block to Cursor |
| Move Block Group to Cursor |
alt + [ |
| Move block end to Cursor |
| Move Block Group end to Cursor |
alt + ] |
| Strech block start to Cursor |
shift + [ |
| Strech block end to Cursor |
shift + ] |
| Set Preview REange to Selected Blocks |
F |
| Divide Selcted Blocks at Cursor |
alt + D |
