This node compares three input values. When the value is in between the minimum and maximum values the result will be output.
In Range Setup
Type |
- Float – Individual X, Y or Z data.
- Integer – These are whole numbers.
- Vector – Combined XYZ data.
Result |
When the value is in between the min and max values this will be on. |
Value |
This is an input value. |
Min |
This value can be set within the node or be an input value. It is also the minimum value range. |
Max |
This value can be set within the node or be an input value. It is also the maximum value range. |
Size |
