Surface Setup
| Mode |
| Position Source | The position of the surface can be assigned a source object. |
| Align Center | Pressing this button will align the center of the surface to the center of the four points. |
Point Setup
There are four points to set up, each is set up the same way and creates a surface object.
| Relative Position | The XYZ coordinates for each point can be assigned here. |
| Update Position | Pressing this button will update the position of this point. |
