This takes in the source text and splits the text into multiple outputs.
*This node is very useful for splitting up incoming UDP and TCP data.
Split Text Setup
Source |
This is the input text. |
Split Character |
This is the character that shows where the text would be split into separate results. |
Result 1 |
This is the first output result. |
Result 2 |
This is the second output result. |
Result 3 |
This is the third output result. |
Result 4 |
This is the fourth output result. |
Result 5 |
This is the fifth output result. |
Result 6 |
This is the sixth output result. |
Size |
