This node converts incoming float values into a timecode output.
| Time | This is the float input for the time value. |
| Timecode | This is the generated timecode output. |
| Hours | This is the integer output of the hour value generated by the timecode. |
| Minutes | This is the integer output for the minute value generated by the timecode. |
| Seconds | This is the integer output for the second’s value generated by the timecode. |
