MTC is a MIDI timecode, which was initially made to keep MIDI equipment synced.
Timecode in Stage Precision can be used to provide this for Outputs, to drive the Timline, to use it for Recordings and to access it inside the Node system.
MTC IN Setup
Devices Input and Output MIDI devices can be selected from the drop-down lists.
MTC MIDI Controlled Timecode – when on this will be used.
MMC MIDI Machine Control – when on this will be used.
FrameRate The framerate can be altered here.
To open a floating monitor window of the incoming TC, click on this icon:
