!This IO-Connection is replaced since 1.1.46 with a Sensor Object !!
Sick LMS Setup
Output
| Name |
| Remote Host |
This is where the target IP address of the host can be input. |
| Remote Port |
This is the port that the data package will be sent to. |
| Interface |
| Is Connected |
When on, the Sick LMS is connected. |
Device
| Name |
| AutoStart |
When on, the device will automatically start. |
| Device Type |
The device type will be displayed here. |
| Status |
The status of the device will be displayed here. |
| Device |
The device name will be displayed here. |
| Start Angle |
The start angle will be added when the device is connected. |
| Stop Angle |
The stop angle will be added when the device is connected. |
| Angle Offset |
The angle offset can be altered manually. |
| Resolution |
The resolution will be added when the device is connected. |
| Scanning Frequency |
This will be added when the device is connected. |
| Axis |
- XY – The data will only affect these two axes.
- XZ – The data will only affect these two axes.
| Invert X |
When on, the X-axis will be inverted. |
| Invert Y |
When on, the Y-axis will be inverted. |
Scan Area
| Name |
| Viewer |
When pressed the device connection window will be displayed in the viewer. |
| Width |
The width of the scanning area can be set. |
| Hight |
The hight of the scanning area can be set. |
| Position |
The position of the scanning area along the two selected axis can be set. |
| Viewer Zoom |
The zoom area in the viewer can be altered. |
| Cluster Method |
| Min Point Size |
The minimum point size can be changed. |
| Naive Max Point Distance |
| Kmeans Max Point Count |
| Kmeans Max STD DEV |
| Blob Threshold |
| Blob Group Distance |
| Blob min mass |
| Blob max mass |
Commands
| Name |
| StandBy Device Command |
This button will turn the device off and put it on standby. |
| Start Device Command |
This button will turn the device on. |
Sick LMS Mapping
