This node calculates the angles between two input vectors.
Vector Angle Setup
A |
This is the first vector input. |
B |
This is the second vector input. |
Angle X |
The angle between the X position of A and X position of B. |
Angle Y |
The angle between the Y position of A and Y position of B. |
Angle Z |
The angle between the Z position of A and Z position of B. |
Size |
