The event filter, filters out the event name. Shortening the full trigger name to only the change of event.
Event Filter Setup
Event |
This displays the input event path. |
Source Object |
This is the object which the event is based on. |
Action Object |
This is a chosen object which will action the found trigger. |
Function |
This shows the event trigger or function. |
Found |
When on, the action object has been found. |
Size |
