Phidget Setup
Device Serial |
The serial number of the device will be displayed when connected. |
Encoder 0 |
The value of encoder 0 will be displayed here. |
Autorange 0 |
When on, the ranges will be generated automatically. |
Invert Range 0 |
When on, the min and max range values will be inverted. |
Range 0 |
The minimum and maximum values can be added here. |
Encoder 1 |
The value of encoder 1 will be displayed here. |
Autorange 1 |
Invert Range 1 |
Range 1 |
Encoder 2 |
The value of encoder 2 will be displayed here. |
Autorange 2 |
Invert Range 2 |
Range 2 |
Encoder 3 |
The value of encoder 3 will be displayed here. |
Autorange 3 |
Invert Range 3 |
Range 3 |
Digital Inputs
Input 0 |
When on, this input is connected. |
Input 1 |
Input 2 |
Input 3 |
Compatible Input Objects
Click this icon to range the incoming Values.
Node Mapping
Module Info |
The module information will be displayed here when connected. |
Input 0 |
This will be on when the output is connected. |
Input 1 |
Input 2 |
Input 3 |
Editable |
When on, the node is editable. |
Locked |
