This is the input protocol for PosiStageNet data which is positional tracking data of objects.
PSN IN Setup
Input
| Name |
| Multicast Connection |
When on, data can be sent to multiple recipients. |
| Multicast Target IP |
| Interface |
| Is Bound |
| Server |
Server name will be displayed here when connected. |
| Rotation Type |
- Orientation – This rotation type correlates to the points of a compass.
- Euler – This rotational type is relevant to a rigid body rotating on a single axis point.
| Up |
- Y-Up – When this is selected the Y-axis will be up.
- Z-Up – When this is selected the Z axis will be up.
| Tracked State from Velocity |
When on the velocity will have an impact on the tracked state. |
*Check the Calibration/Allignment Tool here.
*Check the Sync Tools here.
PSN IN Mapping
| Name |
| ID |
This is the ID number of the incoming data. |
| Name |
- Object Name – The input will look for the object name.
- ID – The input will look for the ID number.
- Custom – The input will look for the custom incoming name.
| Custom Name |
A custom name can be manually added here. |
| Position |
When on, the incoming position data will be used. |
| Rotation |
When on, the incoming rotation data will be used. |
| Velocity |
When on, the incoming velocity data will be used. |
| Acceleration |
When on, the incoming acceleration data will be used. |
Transform
| Name |
| Position |
- Global Position – The object will be affected by the global position of the data.
- Relative Position – The position of the object will be relative to the tracking data.
| Rotation |
- Global Rotation – The object will be affected by the global rotational data.
- Relative Rotation – The rotation of the object will be relative to the tracking data.
Status
| Name |
| Tracked State |
| Enable Recording |
When on, position data can be recorded and used. |
Compatible input objects
