The System requirments of Stage Pecision are the following:
Component | Minimum | Recommended |
RAM | 16GB | 32GB or more |
Processor* | 6 Cores with a base frequency of 2.9 GHz | 10 Cores or more with a base frequency of 3.7 GHz or higher |
Graphics** | Any modern NVIDIA or AMD graphic card** | NVIDIA GTX/RTX cards with CUDA support |
Hard Disk | 2GB free space for software and project files | 2GB free space for software and project files |
Network*** | 2 network interfaces | 4 or more network interfaces |
USB**** | 1 USB Typ A for the dongle | multiple USB Typ A 3.0 or higher |
OS | Windows 10 64bit | Windows 10 64bit |
*Less cores with a higher base frequency are more efficient as multiple cores with lower base frequency.
**Some devices (like a Kinect Azure) needs a NVIDIA GTX/RTX cards with a CUDA driver to work.
***Stage Precision supports multiple network interfaces to seperate different protocols/connections.
We recomend to use for each data stream an own network interface to avoid network issues.
****Some devices (like depth cameras) needs the full bandwith of a USB-PCI lane.
If you want to connect multiple depth cameras you need to expand your system with additional USB 3.0 or higher PCI cards.
