Panasonic AV-HS50 Setup
Output
Remote Host This is where the IP address of the host can be input.
Remote Port This is the port that the data package will be sent to.
Interface This is the IP address of the local network interface which should be used for this connection.
Is Connected When on, the device is connected.
Reconnect This button can be pressed to reconnect the device.
Get Status The button can be pressed to get the status of the device.
Crosspoints
Bus A The output can be assigned here.
Bus B The output can be assigned here.
Program Bus The output can be assigned here.
Preview Bus The output can be assigned here.
KeyS Bus The output can be assigned here.
KeyF Bus The output can be assigned here.
Pin P1 Bus The output can be assigned here.
Aux 1 Bus The output can be assigned here.
Auto Transition Control
Wipe This button will trigger a wipe.
Mix This button will trigger the mix.
Key Trans When on, the key transition will be on.
PinP1 Trans When on, the transition will be on.
PinP2 Trans When on, the transition will be on.
FTB Trans When on, the transition will be on.
DSK Trans When on, the transition will be on.
Cut Transition Control
Background Pressing the button will trigger this transition.
Key Pressing the button will trigger this transition.
PinP1 Pressing the button will trigger this transition.
PinP2 Pressing the button will trigger this transition.
FTB Pressing the button will trigger this transition.
DSK Pressing the button will trigger this transition.
Tester
Send Trigger The trigger message can be manually added.
Send Pressing this button will output the trigger.
Answer The answer from the device will be displayed here.
