Phidget Setup
Device Serial When the device is connected the serial number will be displayed here.
Remote
Host This is where the IP address of the host can be input.
Port This is the port that the data package will be sent to.
Voltage Inputs
Input 0 The voltage of this input will be displayed here when connected.
Input 1 The voltage of this input will be displayed here when connected.
Input 2 The voltage of this input will be displayed here when connected.
Input 3 The voltage of this input will be displayed here when connected.
Input 4 The voltage of this input will be displayed here when connected.
Input 5 The voltage of this input will be displayed here when connected.
Input 6 The voltage of this input will be displayed here when connected.
Input 7 The voltage of this input will be displayed here when connected.
Digital Inputs
Input 0 When the digital input is connected this will be on.
Input 1 When the digital input is connected this will be on.
Input 2 When the digital input is connected this will be on.
Input 3 When the digital input is connected this will be on.
Input 4 When the digital input is connected this will be on.
Input 5 When the digital input is connected this will be on.
Input 6 When the digital input is connected this will be on.
Input 7 When the digital input is connected this will be on.
Digital Output
Output 0 To enable an output each individual output will need to be turned on.
Output 1 To enable an output each individual output will need to be turned on.
Output 2 To enable an output each individual output will need to be turned on.
Output 3 To enable an output each individual output will need to be turned on.
Output 4 To enable an output each individual output will need to be turned on.
Output 5 To enable an output each individual output will need to be turned on.
Output 6 To enable an output each individual output will need to be turned on.
Output 7 To enable an output each individual output will need to be turned on.
